Insufficient Flooring Reinforcement Problem
erdincyorulmaz
I'm getting an insufficient slab reinforcement error. I keep getting an error even though I reduced the right upper reinforcement spacing and changed the reinforcement diameter in the slab. I am waiting for your help. Good work.
Hello, It is the upper additional reinforcement of the floor in the console reinforcement continuity in console floors. The additional reinforcement of the reinforcement axle of the slab in the continuity of the reinforcement flow, which gives a warning for the solution of the as(-) problem, should also be changed. In the project you added, change the upper left reinforcement of the reinforcement axis no. 1 of the adjacent slab D08 to solve the AS(-) problem in the reinforcement axis no. 1 in the D05 slab. In this case, the As(-) problem will be fixed. Note: The elevation and height of the stairs are not compatible with the ground floor. For a more precise calculation, we recommend making the analysis by reducing the finite element widths of the slab, curtain raft. (eg 25 cm) Good work
