I can't thank you enough. The presence of valuable engineers like you in this forum helps us to develop professionally as well. The problem was solved by putting a basement curtain on the part where the stairs will sit, thanks to you, and supporting the ladder on that curtain. I forgot to choose A11, I fixed that too. As for the coordinates, I manually entered the dd2 and dd3 parts in the analysis section. I calculated with the spectrum values in the correct coordinates. I think there is no problem now. Thank you very much.
