Increasing the height of just one space on the top floor???
celikbey
I opened the topic here:
but I think I opened it in the wrong place, moderator friend I couldn't reach (s) either so he could delete the topic. Can you answer here? Thank you (sorry if we're wrong)
"proisa":ln0ml9mc" said:
If the area where you will increase the height is divided by a frame (with beams) 1. Give an upper level to the columns where the beams are connected (For example +50cm to increase 50cm) 2. Give the beams the same value. Give it to me.
Hello. I've already upgraded. I was wondering if it would be a problem in terms of regulation and system. Thanks for your attention...
There is no problem in terms of regulation. But in terms of the system, I recommend you to solve the structure as a semi-rigid diaphragm.
