Mr. mafmim My suggestion: --Column (B) errors, --Rib error in geometry control, --Fix the stair support conditions --The narrow sides of the columns are 30 cm, --Make the S5 column a curtain to create symmetry,(It would be good if the K5 beam is also supported It happens.) -- K19 and K22 (25/50) beams are stuck into the K5(25/32) beam on the 1st floor ceiling. Make beams K19 and K22 25/32. Increase the width of the beam K5, (THIS MUCH STUD IS NOT SUITABLE) --Give the horizontal soil load from the raft (D14) slab to the P6 and P7 bulkheads. Take it easy Ünver ÖZCAN EK: MOLD PLAN
