Hello, I have a problem in my project. For example, when I copy a column in the basement to the ground floor and increase one dimension of the bottom column as a result of the analysis I made later, I get an incorrect column placement error at the top in the geometric control. It is present in every column. They work from the same axle, there is no problem such as top jeans etc. What could be the reason for this warning? I also get the error of insufficient reinforcement on basement curtains. What can I do to fix this problem? Because the file size is large, I deleted part of the project and added it. Good work everyone
