I ran into some problems with rib and cassette flooring when I made a solution with a semi-rigid diaphragm in a Rib and Cassette flooring system. As seen in the pictures, when a cassette slab consisting of 10 cm ribs and 15 cm middle ribs is accepted and the system is solved as a semi-rigid diaphragm, the ribs in both directions appear as 10 cm in the reinforced concrete menu. There is no problem when the same system is solved with a fully rigid diaphragm. There is something wrong with the drawings as well. Looking forward to your help, Thanks in advance.
