antediluvian35
In my project, I could not connect the K7 and K8 beams to the columns to which they will be connected, without fail. Therefore, the tiles I want are not formed. Can you help me. I am attaching the project.
Thank you very much Sent from my MI 4W using Tapatalk"2m project":33v03ubc" said:Hi; If you change the floor heights of 4cm, 3cm and 4.2cm in your project to 400cm, 300cm and 420cm, your problem will be solved. Also, you should enter the beams K21, K3, K39 in parts with different naming between the cantilever beams Regards.
