Inclined Steel Column
serdagi
Hello, I searched in the forum but could not find it, can we give curvature (not curvature) to steel columns as well as reinforced concrete columns? good work everyone...
first of all, thank you for the answers, but when you do as you say, the basic anchor also bends as in the attached picture. I just want the column to bend.
As far as I understand, Mr. NYILMAZ first defined an inclined column on a short element. I want it to adapt to the slope, including the anchor plates, as in the attached picture. However, thank you very much for your suggestion.
Hello there; We cannot perform the correct creation of the anchor details for the inclined column you want in the program. We thank Nyilmaz for his suggestion. Notes have been taken for the necessary work regarding the compatibility of the column foot with the inclined columns as you have sent in the last image. As a temporary solution, you need to use an oblique column over a short straight column for now. Good work.
