Hello friends, I am having a big problem in defining slanted flooring, I would be glad if you could help me. Can you guide me for the situations I mentioned below? 1- When we look at the attached project, there are slant slab definitions at the top and bottom. Of these, the flat slab (D4) was defined at 0.00 level, and the slab defined at +4.00 level was inclined and joined to 0.00 level. However, although the beam (K8) at the lower level of the slab at +4.00 level penetrates the slab at 0.00, the program does not see this beam at 0.00 and gives a drawing without dividing the 0.00-level slab in the formwork plan. I did not know in terms of solution, but since the beam is not visible in the formwork plan, there is a high risk of being forgotten in practice. 2- Due to the problem at the top, a sloping slab (D105) was defined at 0.00 level at the bottom, and then a flat slab was defined at 0.00 level. it shows on the ground. The reinforcements are overlapping. Maybe editing can be done when the same reinforcement comes out, but if it is different, how will we understand which reinforcement belongs to which flooring? 3- Also, when checking the geometry, it gives vertical continuity error in the columns to which the inclined floors are connected.
