The steps of transferring to Tekla Structures can be summarized as follows: 1) First of all, open the ideCAD Static model you want to import and select from the menu. You save the model as a .dmp file by following the path "Project > Export > Tekla.dmp" 2) Then you run Tekla Structures installed on your computer. Currently, the export process is Tekla Structures' It can be applied to all versions of . from 17.0 to 2016i. 3) You open an empty model in Tekla Structures or an existing model that you want to add the ideCAD Static model and wait without closing this software. 4) While Tekla Structures is open, "C:\Program Files The Tekla open on your system where you will transfer from the settings on the right by running the "ideToTekla.exe" software in any of the Turkish or English folders under the \ideCAD\ideCAD Statik\ideToTekla" folder. ideCAD Sta with Structures version You choose which elements/features in the tick model to transfer. 5) You start the transfer process by selecting the .dmp file you created in the first step with the "Choose a file..." button. 6) Since the transfer process is done with API commands, depending on the size of your model, when you switch to Tekla Structures, you will see that your ideCAD Static model is created here step by step. 7) While the transfer process continues step by step, if there are any profiles that are not compatible with Tekla Structures' library for the profile type/name and material names defined in the ideCAD Static model, warning screens are also opened as a popup menu for the user to define them. The transfer of compatible ones will be done automatically without any user intervention.
