Hello, you can use PURGE command in Autocad environment. You will clear unnecessary objects. If the DWG drawing is too large, you can try to import after separating each drawing plan. If you add the DWG file, we can determine the cause of the problem. Can you write the ideCAD version you are using. Good work."alisenay":1dedqq5y" said:Greetings; While importing a .dwg file to the 2D window I created in the ide, the program closes itself every time. Can you help to solve the problem? Good work
Using DXf is your choice, but there is no such obligation. It would be helpful if you send the dwg file to us. Good work..."alisenay":3ga8i2ie" said:After converting to dxf format and making the scale adjustments, the problem is gone. It looks like I will import dxf from now on.
