idecade file transfer from sta4cad
emine güven
Hi, I am using İdecad Architecture program for architectural drawing. The civil engineer friend I will work with said that he is working with sta4cad. Normally, I would take the file from idecad static and process the architecture on it and continue drawing. Is it possible to import files from Sta4cad to İdecad? I don't want to manually enter the column-beam-floors from the beginning. I would be glad if you help. Thank you.
Hello there; I recommend you to try transferring data from Sta4CAD to IdeArchitecture or Static with IFC format. Although it does not work very well for now, I think it will be more efficient in future updates. Best regards.
"2m project":2n9tlcfq" said:
Hi, I suggest you try transferring data from Sta4CAD to IdeArchitecture or Static with IFC format. Although it doesn't work very well for now, I think it will be more efficient in future updates. Best regards.
Thank you, I will try.
