ideCAD v10 Rigid Diaphragms
Apocalpyse
Hello, In the project I am working on in Ide 10, there are more than one rigid diaphragm on some floors, these are caused by mezzanine pulls on some floors, and due to floors sitting at different levels on some floors. For this reason, I do not have a problem with having more than one rigid diaphragm, but my problem is with the drawing. In Ide 7, when I did not want to see the rigid diaphragm numbers in front of the beam names in drawings with multiple different rigid diaphragm structures, I made the names of all the diaphragms the same and got rid of this problem. How can I do this in ide v10. The problem is all about creating the formwork plan and beam opening. so that the naming continues as KZ01 - KZ02 (not as KZA01 - KZB02) Thank you, good work. An example of legacy application.
The forum's search feature will help you with this and any questions you may have. There is a Search box at the top right. If you write "floor index" here and press the search button, you will find hundreds of pages directly related to this subject.
Thank you for showing me how to search the forum. I've already done a search on the subject. Entered this way (This is already if no changes are made)
Result:
Separated with a comma
The middle part is ridiculous
If no index is written
This is the result, everything looks good, but the building inspection company does not accept it. Floor indices will appear...
Separated with commas as a result the names of objects not connected to the rigid diaphragm are ridiculous. I couldn't upload the original project because it was too complex. I talked to the Istanbul office. I think a fix will be needed. Thanks
Hi, To make the nomenclature as in version 7, 1. Analyze Structure. Enter in the 2nd Floor General Settings. Write the indexes of rigid diaphragms separated by commas. (ZA,ZB) 3. Get a drawing. If you want to make the naming layer by layer independent of the index in the floor general settings. Leave the index line blank in the 1st floor general settings. 2. Name each floor by indexing it with automatic object name. Good work
