ideCAD v10 Raft Floor Gap
sonsamuray
Hello, I wonder why it is problematic to create a raft floor space in ide10, as we did in ide 7 and 8 before? Drawing a raft edge in the space I opened is causing a problem. Is there a different situation?
Re: İdecad 10 Raft Floor Space Hello
No. My suggestions: --You should solve the building mixed, not limited,( I don't think it will save it.) --The gaps you will open in the hollow block do not cut the asmonel beams, --Select the RDZ03 slab given in the geometry control with select object and press delete, --Fix the errors in the geometry control, --The columns remain in the air, give their height -90 cm and press the raft --Model the RD07 radial to include S03-S04, FINAL WORD: Return to the column-beam-plate system.
In v10, the mat slab spacing is defined as in 7 and 8. Logically there is no difference. If you had entered the same project in 7 or 8, you would probably have asked the same question. In your project: 1. The columns stay in the air. According to the data entry you entered, you should give your columns -0.90 elevation 2. First define the raft space and the raft edge, then enter the S03 column. The problem you mentioned will not occur. Sample data entry: Plan view of the revised project: 3. The raft tile you defined in the raft cavity remains in the air. You must adjust the element elevations. For such gaps (elevator shafts), I recommend you to review the following links:
Good work
"HakanŞahin":1so2qizu" said:
v10, the raft slab gap is defined as in 7 and 8. There is no difference logically. If you had entered the same project in 7 or 8, you would probably ask the same question. In your project: 1. Columns in the air According to the data entry you entered, you should give your columns -0.90 elevation 2. First define the raft space and the raft edge, then enter the column S03. The problem you mentioned will not occur. Sample data entry: Plan view of the improved project: 3. The raft tile you defined in the raft space remains in the air. You should adjust the element elevations.For such gaps(elevator shafts), I suggest you to review the following links:
[ url]http://www.idecadsupport.com/forum/viewtopic.php?f=5&t=4426&p=20094&hilit=asans%C3%B6r&sid=60698590c1e1fcf54802a63d4bbff15f#p20094[/url]
Good work
Thank you.
"unver":2w1swmfp" said:
Hello
"sonsamuray":2w1swmfp" said:
Is there something different?
No. My suggestions: --You should solve the building not limited, mixed, (I don't think it will save it.) --The gaps you will open in the hollow block should not cut the asmonel beams, --Select the RDZ03 slab given in the geometry control with select object and delete it, --Fix the errors in the geometry control, -- Columns are in the air, press the raft by giving -90 cm in length, --model the RD07 raft to include S03-S04, LAST WORD: Return to the column-beam-plate system. Ünver ÖZCAN
Thank you very much for the warnings. It seems that I need to remove the curtains from the system in order to choose the mixed A31 system. So why is it forbidden in the regulation to solve in the system limited to 2 curtains?
