Hello there; Since the walls are entered into the system as wall elements in your project, the wall load entered in the Beam settings - Static / reinforced concrete tab is not taken into account. The main thing is the wall element. If you delete the walls from the model, you will see that the calculations you want are made correctly. If you want to add an additional load without deleting the wall elements, you can define the load as you want in the desired load state by right-clicking on the beam in the perspective window and adding load. * The beam information with the desired load transfer provided in the model where the walls are deleted. Best regards.
