ideCAD v10.20 version error
Re: idecad 10.20 version error Hello, There is no such problem in the program. The problem may be related to your project. If you attach your project file, we will try to help.
Re: idecad 10.20 version error Did you try it in version 10.20 There is no problem with the dock in 10.17, but there is a problem in the 10.20 version.
Re: idecad 10.20 version error If you add the versions of the scaffolding project, which was calculated in 10.17 but not calculated in 10.20, both saved in version 10.17 and version 10.20, we will examine it.
Re: idecad 10.20 version error I don't know how to upload the project here yet, how can I do it if you have an e-mail address, I can send the project to you from the 10.17 version
Re: idecad 10.20 version error The project you added is not a scaffolding project. However, in version 10.20, analysis can be performed on the project when the scaffold is drawn with the project settings you send to any side.
Re: idecad 10.20 version error I guess you didn't understand what I meant.. I apologize for my incomplete explanation. When I convert the project I sent to a scaffolding project at 10.17, I have no problems, but when I convert it to a scaffolding project at 10.20, the program closes when I analyze.
Re: idecad 10.20 version error If you add your project file with its broken state while analyzing in 10.20 version, we can examine your problem in more detail.
"Hüseyin Yalçın":4bl674ln" said:
but when I convert it to a scaffolding project at 10.20, the program closes when I analyze it.
Emrah Bey gave me the same in the screenshot The scaffolding program is running. Drawing can be taken. There is no problem. To clarify the situation, save the closed program data before analyzing and share it here. Ünver ÖZCAN
