ideCAD tdy options
instinst
Hello. . I made the model of my building and 3 options appeared as I marked below in the tdy options. I ticked these 3 options to stay on the safe side. basement ground and 2 storey construction. I chose the 4th degree earthquake zone and r is 7. Do you think I did wrong by marking these 3, can I get your opinion, thanks in advance
Also, when I do an analysis, it says the analysis has been canceled and shuts down the system. I will be glad if you help.
Hello My Suggestions There is no mistake in your choice, D44 BZ-1. deleted on the floor, Stairs deleted, In this case, you can get results. --Support the stairs, --make the raft flooring alone, --don't open the windows side by side in the basement, a short column is formed. a jumping sheep, Unver ÖZCAN
