ideCAD System Requirement
berkehan
I'm going to buy a low budget laptop. Will I have a problem with the operation of the program with the following features, what are the system requirements of Idecad? Also, what is the importance of the video card in analysis? Thanks. - AMD Ryzen 3 3200U Processor (2 real, 2 virtual cores. 2.6 Ghz Processor Speed) - 8 GB 2133 Mhz Ram - Nvidia Mx 230 graphics Card (2 GB GDDR5) - 256 GB SSD - 1366x768 Resolution
High performance system requirements for desktop: -Intel i9-9700k -64 bit 10 operating system -32 Gb ram -Nvidia Geforce GTX 1060 -UHD Monitor resolution -SSD Price/performance option for desktop system requirements: - Intel i5-9600k - 64-bit Windows 7, 8 or 10 operating system - 16 GB RAM - Nvidia GeForce GTX 1050 discrete graphics card - 1920x1080 monitor resolution High performance system requirements for laptop: - Intel Core i9-8950HK - 64 bit Windows 10 operating system - 32 GB RAM - Nvidia GeForce GTX 1060M discrete graphics card - En at least 1920x1080 monitor resolution Price/performance option for laptop system requirements: - Intel Core i5-9300HQ - 64-bit Windows 7, 8 or 10 operating system - 16 GB RAM - Nvidia GeForce GTX 1050M external video card - 1920x1080 monitor resolution For recommended system requirements for desktop and laptop computers, you can review the link below.
"berkehan":11acgui6" said:
I will buy a low-budget laptop. Will I have problems with the program running with these features, what are the system requirements of Idecad? And what is the importance of the video card in analysis? Thank you.
The program will run on the laptop with the feature you selected but you may find its performance insufficient. Depending on the size of the project, 8Gb may be less. We recommend an intel processor instead of AMD. The graphics card has no effect on analysis, it has an effect on 3D visualization.
"HakanŞahin":fgjgqt3m" said:
"berkehan":fgjgqt3m" said:
I will buy a low budget laptop. Will I have a problem with the operation of the program with the following features, what are the system requirements of Idecad? Also, what is the importance of the video card in analysis? Thank you.
The program works on the laptop with the feature you selected, but you may find its performance insufficient. Depending on the size of the project, 8Gb may be less. We recommend an Intel processor instead of AMD. The graphics card has no effect on the analysis, it has an effect on the 3D visualization.
You should definitely get a model with an external graphics card. Because, as Mr. Hakan said, it takes time to display the analysis results in the visualization window of the analysis results. For this, the nVidia 1050 or 1650 models available in the laptops on the market are quite sufficient.
Thank you for the replies. Unfortunately, Levent Bey's suggestions are very expensive. Mr. Hakan, in comparisons, Amd Ryzen 3, i7's 4-5. It gave better results than its predecessors. Even if it's not very fast anyway, it's low budget after all. The one with 12 GB of ram did not have an external video card either. If not, I'll try to upgrade. MafiaMax graphics card external. But 1050,1650 these are available in expensive models. Frankly, I don't see any need for it, just for 3D. The graphics card in the current desktop pc is older, but I'm not having any problems. It just twitches in between. My purpose in asking was whether it meets the minimum requirement, I guess I got the answer for that too. I understood it as "It does the job, but a little slow". I hope I understood correctly. Thank you all.
I want to buy win 8.1 pro 64 bit operating system. Can win8 users have problems with idestatic updates in the future?
"ersinmat":2b3iemz2" said:
I want to buy a win 8.1 pro 64 bit operating system. Can win8 users experience problems with idestatic updates in the future?
Hello, we recommend you buy Windows 10. Microsoft, future technical support for Windows 8 Therefore, you may have problems in the future. Good work
I wonder if these features are enough for Idecad 10 -INTEL CORE i5 10th GEN PROCESSOR - 8 GB DDR4 RAM - 256 GB SSD - 1 TB HDD - NVIDIA® GeForce® MX130 2 GB GRAPHIC CARD
"Tasyapi232323":1abc9xmj" said:
I wonder if these features are enough for İdecad 10 -INTEL CORE i5 10th GEN CPU - 8 GB DDR4 RAM - 256 GB SSD - 1 TB HDD - NVIDIA® GeForce® MX130 2 GB GRAPHIC CARD[ /quote] Hello, You can run the program with the system you specified, but you may not find its performance sufficient. We recommend a GTX series graphics card, 16 GB ram and i7 processor. Good work.
