ideCAD Steel Structure Analysis
ermanguc
Good day, I need to make an easy steel structure project. After the analysis, although I have followed all the steps in the training videos on Youtube. When we come to the reports, Ne Kirişte Çelik is in love. Nor does it take the beam or steel purlin load on the columns. It only takes the self-weight of the element. I couldn't find the solution of putting the loads coming from the top down. Any idea as to the reason for this? Thank you very much in advance
In the steel purlin settings menu, in the extensions tab, set the vertical offset to a value of 3 cm or greater. Or make the lovers defined from the top. The purlins are defined in the middle and with the beams, in this case, the coatings are connected with the main beams. Make sure that the coatings are disconnected from the beams and only transported with purlins.
First of all, thank you for your interest, Mr. Ismail. I applied what you said, but I couldn't get analysis again. To make an experiment, I made a connection with ipe 500 2 columns and ipe 240 beams on these two columns on a different page. However, after the analysis, I could not see the load of the beam in the reports of the columns. only the self-weight is visible. I can't figure out why. I will be glad if you help
Hello there; Change the purlin positions in the purlin settings. The coatings are required to transfer the load to the purlins. Due to your roof modeling, only self-weight appears. I edited your project, please review it again, the visuals will help. Good work.
Thank you Nurgül Hanım. Using the information you provided, I managed to give the lovers the coating loads. It will be a lot, but the top loads are still not visible in the Column-Beam-Singular basic reports. For example, I made a simple application. I would be glad if you help
Hello there; If you mean the total loads from the building in the basic report, our report format is not like that at the moment. If you get a single foundation report, you can see the designed moment and pressure forces. You can access all diagrams from the right-click analysis model viewing frame results section, so you can see the loads used in the dimensioning of the foundation.
The first video of the training is included in the attached link. I recommend you to watch 5 webinar training videos. It will clear many question marks about the program. Good work.
