ideCAD Steel Floor Load Distribution
mmstarsln
Hello, I'm stuck on a small detail, but I don't want to skip. There is a section called LOAD DISTRIBUTION in the loads section of the İdecad Steel flooring drawing. What exactly is meant by this load distribution? I would be glad if you inform me. Good work.
Re: İdecad Steel Flooring Load Distribution Hello ; Sorry for the delay. If you choose two directions in the load distribution section, the load will be shared between the beams in both directions of the floor. However, if you choose one direction, the beams in one direction will take the loads from the floor according to the angle value you give. After making these different choices on the slab, you can analyze the difference between them and view them in the right-click analysis model - loads-loads acting on the slab section. Entering 0 or 90 degrees in one direction allows you to specify which direction you want to transfer load to your beams. Good work.
