ideCAD STATIC V7
cassabotanic
Re: ideCAD Static V7 New Version Autocad style command line and dynamic input was a surprise for me as well. I thought that these possibilities would be given to users with the steel program to be released in the future.
Re: ideCAD Static V7 New Version NO ONE WAS LOOKING AT THESE TIMES, I SHOULD BE WAITING FOR THE FORUM, MAYBE IT WAS WRITTEN, BUT IT WAS NOT A SURPRISE TO FRIENDS LIKE ME, I HOPE THEY ARE WAITING WITH SURPRISE.
Re: ideCAD Static V7 New Version I think it will be much better.. In the data entry, we can connect the beams to the curtains as we connect them to the columns.
"saridurmus":35d67baq" said:
NO ONE WAS LOOKING AT THESE TIMES, I SHOULD WAITED FOR THE FORUM, MAY BE SAYING THE ARTICLE IS COMING, BUT FRIENDS LIKE ME IT WAS NOT SURPRISE. I was surprised but that's not what I expected.
Re: ideCAD Static V7 New Version Good luck... By the way, is there any clear information about the release date?
"aksa":ddxayeht" said:
We can connect the beams to the walls as we connect the columns to the columns, Insha'Allah
Hello, The restrictions on connecting beams to the curtain in the data entry have been removed. , tile identification issues encountered in some cases are also fixed.
Re: ideCAD Static V7 New Version Good day It is a nice feature to include stairs, vaults and domes as shell elements in the whole building analysis model, but will this vault and dome be calculated and drawn in reinforced concrete? and will it be possible to define a rotating calculation axis for spiral staircase types. In addition, concrete calculation and drawing of pool projects
Re: ideCAD Static V7 New Version Excellent idestructure rebriks that showed their difference ideyapı Hakan BECERİK MSCivil Eng.(CAState Unv.)
Re: ideCAD Static V7 New Version Bored pile drawings ..? Latitude rib beam on ribs exceeding 4 and 7 meters ...? Increasing the retaining curtain models (anchored etc.) ..?
Re: ideCAD Static V7 New Version In ribbed and cassette slabs, a section can be added to write down the weight of the hardwood. Usually stone weight is not taken by users. In this way, this situation is overlooked in many projects, causing misuse. It would be nice if this issue is fixed in version 7. Good work...
Re: ideCAD Static V7 New Version Hello. My suggestions for ideCAD Static V7 New Version.. 1. Ability to solve projects compatible with ACI, Eurocode and SNIP codes and English language support. 2. Static, reinforced concrete calculations and detail drawings, reinforcement tables and quantities of domes and vaults. 3. Static, reinforced concrete calculations and detail drawings, reinforcement tables and quantities of stairs. 4. Modeling and detail drawings of beams with gusel and variable cross-sections. 5. Refurbished rib, cassette beam detail drawings. 6. Renewed continuous foundation beam detail drawings. Thank you and I wish you continued success.
"Bolvadinim":n44ijcjp" said:
Hi, my suggestions for ideCAD Static V7 New Version.. 1.ACI, Eurocode and SNIP code compatible project solving and English language support 2. Static, reinforced concrete calculations and detail drawings, reinforcement tables and quantities of domes and vaults 3. Static, reinforced concrete calculations and detail drawings of stairs, reinforcement tables and quantities 4. Modeling and detail drawings of beams with gusel and variable cross-section 5. Renewed rib, cassette beam detail drawings 6. Renewed Continuous foundation beam detail drawings. Thank you and wish you continued success..
Dear Bolvadinim, 3. Static, reinforced concrete calculations and detail drawings of stairs, reinforcement tables and quantities. Renewed rib, cassette beam detail drawings 6. Renewed Continuous foundation beam detail drawings. English and German language support, static reinforced concrete calculations of domes and vaults and the "3. , 5th, 6th items" these issues are already existing in ideCAD Why do you want it to be renewed? If you specify, it will not be for version 7, but we can consider it for version 8. We will consider the other issues you have mentioned for version 8, good work
Re: ideCAD Static V7 New Version Awesome thing, super innovation semi-rigid diaphragm thing. I did a search on the internet. They also make programs like Etaps ram risa. Bravo idestruct the "semi rigid diaphragm" thing. Semi-rigid diaphragm becomes even more important when it comes to steel structures, especially in structures with composite flooring system. In addition, the floor of the floor where the rigid structures on the lower floors rise by shrinking and the rising block part sits below must be modeled by taking into account the floors, that is, it should be modeled as semi-rigid. take a look at:
This is also Turkish source
Ismail Hakki Besler" Dear Bolvadinim , 3. Static, reinforced concrete calculations and detail drawings of stairs, reinforcement tables and quantities. 5. Renewed rib, cassette beam detail drawings. 6. Renewed Continuous foundation beam detail drawings.English and German language support, static reinforced concrete calculations of domes and vaults and the "3. , 5th, 6th items" these issues are already existing in ideCAD Why do you want it to be renewed? If you specify, it will not be for version 7, but we can consider it for version 8. We will consider the other issues you have mentioned for version 8, good work[/ quote] Hello Mr. Ismail, 1.-Renewed continuous foundation, rib, cassette beam detail drawings are requested for this reason. Our new beam details have become very beautiful, new stirrup types (hook bends, number of stirrups, beam elevation writings, beam cross section direction arrow line Reinforcements in the beam section are taken out of the section and written with lines, etc.) The renewed format is very beautiful, wonderful.. I meant that these beauties should be adapted to the detail drawings of the foundation beams, ribs, cassette detail drawings. 3.- Since we cannot define a curvilinear calculation axis on round and fantastic stairs, There is a problem in the quantities of equipment and equipment. The domes, vaults, and pools are not drawn. ok that would be nice. Thank you.
"curious":25cf3qyx" said:
Awesome thing, super innovation semi-rigid diaphragm thing. I searched on the internet and they also make programs like Etaps ram risa "semi rigid diaphragm" Bravo idestruct event.Semi-rigid diaphragm becomes even more important when it comes to steel structures, especially in structures with composite flooring system.In addition, the floor of the floor where rigid structures with lower floors rise by shrinking and the rising block part sits under must be modeled taking into account the floors, that is, semi-rigid modeling. see :
This is Turkish source
In addition, Earthquake regulations A2 and A3 irregularity Article 2.3.2.2 issue is resolved, the flooring does not accept rigid diaphragms and semi-rigid diaphragms. when you solve it. And in their truest form
These are also important, but the definition of rigid diaphragm in basement rigid structures, which is encountered in most of the currently designed structures, causes errors in the shear forces of the wall and the effects of these walls on the foundation. This error is due to the rigid diaphragm theory. The semi-rigid diaphragm also solves this problem. Nobody can do this today, except for a few programs like Etaps (including Sap2000).
Re: ideCAD Static V7 New Version Well done, it's very nice and the changes we need... Bülent KAPLAN İnş. Eng.
Re: ideCAD Static V7 New Version Hello; We see that the V7 is equipped with very good facilities. In addition to these possibilities, it would be nice to solve the problems caused by the vertical section change in the panel elements modeled as shells or the joining of the panels at different elevations, together with the V7. I think the attached picture will be self explanatory. (perhaps a mesh algorithm that takes into account intersections, as with tiles, could be in panels) Regards.
