ideCAD Static V7 New Version
Status
Not open for further replies.
admin
Administrator
Staff member
The new version will be available in the fall with many new features such as semi-rigid diaphragms, new tunnel formwork calculation module, 3D reinforcement display and 64-bit support. For version 6 users, the update to Version 7 is free. ideCAD Static V7 features: 1) New tunnel formwork calculation and drawing module -In slabs and mesh-reinforced design and drawing possibilities on panels -Band beam definition and drawings (Band beams are not necessary for analysis ) -Tunnel formwork curtain ratio control (Regulatory equation 3.14) -To tunnel formwork proper mesh reinforcement exposure
4) The entire building as shell elements of stairs, vaults and domes inclusion in analysis model
5) Possibility of cross-reinforced design and drawing, which should be made especially on the tie beams connecting the curtains on the lower floors of high-rise buildings (Earthquake regulation article 3.6.8.4)
6) New tiling features -In addition to automatic tile creation, manual tiling and space creation by defining environmental elements -With the option of drawing tiles in full on the plan facilitating project follow-up -Seeing the effect distance of the reinforcement calculation axes on the floor plan and easily changing it with the mouse -Plan the slab reinforcement calculation axes -Optionally displaying the validity distance of reinforcement axes in the formwork plan -Defining partial reinforcement axis to the floor (automatic recognition of gap and U-shaped floor arms)
8) Rebar layouts with 3D reinforcement inspection module (column/beam/panel) visual inspection (Virtual construction site) -To be able to examine the reinforcements in full screen -Drawing with different colors according to the diameter -Optionally to display only the longitudinal or transverse reinforcements
9) Broken bent axis display option
10) Command line and dynamic input possibilities
11) Drawing the capacity diagram of the curtains, querying the values of a point on the diagram with the mouse 12) Revision cloud object 13) Close unused layers command 14) Offset ability to offset the axes with the offset command 15) Improvement in formwork plan sections
Status
