HakanŞahin
Administrator
Dear Users, You can download the ideCAD Static V6.2 program using the link below: This version has been removed from access. Click
Log in or register now.
for newer versions. List of possibilities: 1. Progressive construction calculation -Determining the true moment envelopes by making the dead load correction required in high-rise buildings with layer-by-layer concrete pouring -Taking into account the change of the elasticity modulus of concrete over time - To be able to take into account the creep effects that occur in the lower floors over time as a result of loading the upper floors - To be able to take into account the shrinkage effects that characterize the shrinkage of concrete according to time - To be able to question the status of the structure after the loading of the pavement and live loads, after the desired time - To define the varying construction times on a floor basis [ b]2.[/b] Calculation of heat differences -Defining two different heat loading conditions as T1 and T2 -Defining heat differences that vary on floor to floor and/or element basis 3. Elasticity module on element basis according to load condition or defining reduction factors for moments of inertia 4. Vertical load solution optionally without rigid diaphragm. 5. Column and panel reinforcement table 6. Ability to select an element to all floors 7. Define "favorites" in object settings and call them with a single command ]8. Automatically take the upper level of the lower element (floor, terrain, other libraries, etc.) while placing library elements. 9. Automatic naming for pile foundation objects 10. Layer layout in stair drawings 11. Separate listing of different concrete classes defined in different floors in performance analysis report Good work ...
