ideCAD Static v10 relative floor offset not recovering
mühendix
IN THE STATIC PROJECT I SHARED THE LINK BELOW, I CANNOT SAVE THE RELATIVE FLOOR DEPLOYMENT. IS THERE ANYTHING I MADE WRONG ACCORDING TO THE 2018 REGULATIONS? DO I HAVE OTHER MISSING POINTS? THANK YOU IN ADVANCE FOR YOUR HELP.
Re: IDE10 RELATIVE FLOOR SHIFT DOES NOT SAVE
"engineering":1ncilvbj" said:
IN THE STATIC PROJECT I SHARED THE LINK OF BELOW, I CANNOT RECOVER RELATIVE FLOOR SHIFT. THANK YOU FOR YOUR HELP
In your project, the building coordinates look the same as the template project. Could you share the building coordinate information so that we can check the given earthquake parameters?
Re: IDE10 DOES NOT SAVE RELATIVE FLOOR SHIFT
"HakanŞahin":1sstwec0" said:
"mühendix":1sstwec0" said:
I CANNOT SAVE RELATIVE FLOOR SHIFT IN THE STATIC PROJECT I SHARED THE LINK BELOW. IS THERE ANYTHING I MADE WRONG ACCORDING TO THE 2018 REGULATIONS? DO I HAVE OTHER MISSING POINTS? THANK YOU IN ADVANCE FOR YOUR HELP.
The structure coordinates in your project look the same as the template project. Could you share the building coordinate information so that we can check the given earthquake parameters?
LOT: 38.61045000 LONGITUDE: 27.43066000
I suggest you to look at the other questions on this topic in the forum.. In idecad version 10.05, first of all, you need to select DD-1 from the wizard, enter the values and save, then select DD-2 and enter the values, and then analyze it. For now, this is the working logic of the program..
"mühendix":18ah68he" said:
IN THE STATIC PROJECT I SHARED THE LINK BELOW I CANNOT RESCUE THE FLOOR DEPLOYMENT. IS THERE ANYTHING I MADE WRONG ACCORDING TO 2018 REGULATIONS? ARE I MISSING ANY OTHER MISSING POINTS? THANK YOU IN ADVANCE FOR YOUR HELP.
In your project, the building coordinates look the same as the template project. ?
LATITUDE: 38.61045000 LONGITUDE: 27.43066000
According to your building coordinates, you should give the DD3 values to the program for the relative floor drift control. However, you seem to be using the same values as DD2. The values you need to enter in the wizard for DD3 are: After you enter the correct values into the program Relative floor drift control will be provided.
Good day. I have read the information on the relative floor drift in the forum and uploaded the information I got from AFAD to the wizard. However, I can't get over the relative floor drift problem. The project I have drawn is a basement+2 storey project. I uploaded my project. I am waiting for your help
"ozguncicek":3c3gq4ln" said:
https://www.dosyaupload.com/anxF
Good day. I installed it in the wizard. However, I can't get over the relative floor skipping problem. The project I have drawn is a basement+2 storey project. I uploaded my project. I am waiting for your help
Hello, In the project you added, the floor bed coefficient was entered incorrectly. (According to the picture you added, it will be 1250000 kg/m3 instead of 1250 kg/m3). Also, although there are no perimeter curtains on the basement floor, the floor is considered rigid. If the floor bed coefficient is entered as 1250 tf/m3 and the analysis is made without accepting the floor as rigid, the relative floor drift problem does not occur. Good work
Thank you for your help, Mr. Levent. When I made the correction you mentioned, the problem was resolved. However, there is a point that I am confused about. Aren't the values in the report image I shared a little too small :shock:
In addition, when I create an ELECTIVE REPORT, project errors appear under the heading "shear safety of column-beam junction areas". How can I solve the situation without enlarging the column sections?
"ozguncicek":3erdfugu" said:
Thank you, Mr. Levent for your help. When I made the correction you mentioned, the problem was solved. However, there is a point that I am confused about, aren't the values in the report image I shared a little too small than 0.008 :shock:
Also, when I create an ELECTIVE REPORT, project errors appear under the heading "shear safety of column-beam junction areas". How can I solve the situation without enlarging the column sections?
In your project, the coordinate and spectrum coefficients were entered in the TBDY 2018 wizard by first selecting DD1 ground motion. The wizard has been registered. Then DD2 was re-entered for ground motion and the wizard was registered again. Relative floor offset values are reasonable for floor class ZC. In Ver 10.06 the wizard will no longer need to be edited twice. Joint Shear Safety problems can be solved by changing the column orientation and misalignment and enlarging its dimensions. Good work
In your project, coordinate and spectrum coefficients were entered in the TBDY 2018 wizard by first selecting DD1 ground motion. The wizard has been registered. Then DD2 was re-entered for ground motion and the wizard was recorded again. Mr. Levent, could you please help me with this statement. So there are some points that stuck in my head. Is there a video application of the operations you have done? After opening the wizard, choosing DD-1 and choosing the ZC floor, I get the values for DD-1 DD-2, DD-3 separately from the AFADIN page that stuck in my head, enter here and save, enter the other data in this interface exactly and save, then do the same. This time when I do it for -2; Do I need to take the same operations from AFAD and apply to this interface and re-register? Also, when I want to login to DD-2 after logging in for DD-1, I get a cancel warning like this. Do we go ahead and enter the new DD-2 value after canceling? I hope I was able to explain. :mrgreen:
"ozguncicek":2j995xfr" said:
The coordinate and spectrum coefficients in your project were entered in the TBDY 2018 wizard by selecting DD1 ground motion first. The wizard was recorded. Then DD2 ground motion was entered again and the wizard was recorded again. Mr. Levent, could you please help me with this statement. So there are some points that stuck in my mind. Is there a video application of the operations you do
How to organize the TBDY 2018 wizard is explained in the attached document. There will be no need for these operations in Ver 10.06 version. Good work
Thank you for the pdf Mr. Levent. However, when I review the project that you sent the corrections you sent above and revise the project in my hand according to your regulations, the reinforcement amount of the project you created in the quantity section is around 10200kg, while in my project I entered the same cross-section and ground values, it turns out to be 12700kg s420. I couldn't figure out what is the reason for this. I have a project that I brought and gives 12700kg of iron quantity. Thanks again for your help.
Hello, while getting the relative floor drift error in the projects, it gives the ratio of the column that is already the maximum in the report. If you want to see the relative story offsets of other columns, how can we see them?
"mühmurat":lfz8s39p" said:
Hi, it gives the ratio of the column that is already maximum in the report, while getting the relative story drift error in the projects. If you want to see the relative story drifts of the other columns, how can we see it?
Hello, The displacements of the carrier elements Perspective screen - analysis model Viewing - deformations tab You can check the link below. Good work
[url ]https://idecad.atlassian.net/wiki/spaces/IBB/pages/836438589/G+reli+kat+teleme+y+ksek+sistem+rijitli+ini+artt+r+n[/url]
