ideCAD Static v10 column closes while receiving application
gyatko
Hello, while Idecad ststik 10 is getting the colon application, the program is closing, I would be very happy if you could help.
Re: İdecad Statik10 column closes while the application is being applied The program is broken while the basement floor column application is being received. Unver ÖZCAN
Re: İdecad Statik10 is closing while receiving column application
"gyatko":pgw3i37p" said:
Hi, the program closes while receiving column application in idecad ststik 10, I would be very happy if you could help me.
Elevator shaft You can delete the wall P19 and get a column application plan. We recommend modeling the elevator shaft as flat without raising the walls and raft foundation, and providing the elevator shaft detail separately
Hello, There will be no problem if you delete the P19 curtain that you defined for the elevator pit in the basement and then get a column application plan.The closure situation is noted in our notes.
Re: İdecad Statik10 closes while the column application is being taken Hello, You can get column application drawings for your project with the "Open Details Outside" option. You can also consider this option.
