Hello there; Please review TBDY 2018 IMO Sample Projects and books on this subject. You can also benefit from the AISC Seismic Manual. You should not choose a common carrier system element for both types. This is about engineering, not programming. If you think about the physical meaning, there are limit situations under the effect of earthquake in both carrier systems as per the regulation. In frames with central diagonal and moment-transmitting, it will be plasticized on an element at the same time by considering both situations, and there can be no loss of bearing capacity due to this situation. It is necessary to determine a situation in real structures related to this situation and adapt the situation to the regulation with experimental and empirical studies. However, in the regulations, both the moment transferring and the common element of the central braced frame are not evaluated. In this case, the program cannot perform any operation automatically. Your main problem is that you shouldn't actually choose partners. According to this logic, you should place the frames with central braces in the other direction, which transmit moment in one direction, without any common elements. You can use the references mentioned above for this. **** In industrial buildings, the articles of the regulation should be interpreted appropriately. For example, in this single storey building of yours, you can choose only the frames with central braces for the final states of the columns and beams, instead of choosing one side with a central brace, which transmits moment, as per TBDY 2018 - Chapter 9. In this way, cross-section control of columns, beams and braces, slenderness control and transfers with the necessary D coefficient in internal forces will be applied. If you examine the regulation, the cases of increasing with D in the moment transmitters and increasing with D in the central diagonal will allow you to understand this interpretation. In summary; Yar. Doc. Dr. As our teacher Cüneyt VATANSEVER stated, common column selection should not be made. In case of selection, the program should not crash, this error has been reported. However, you also have to make a decision together with the engineering interpretation in the selection of the carrier system. As I mentioned, it would be a more appropriate solution to choose only the central braced frame elements so that a common selection does not occur for the project you sent. Good work.
