ideCAD Static Sentinel key not found(H0007) error
melih1892
I installed ideCAD Static from the link on the page, but when I click on the ideCAD Static icon on the desktop after the installation is finished, it gives the error "Sentinel key not found(H0007)", the program does not open. I would be glad if you help.
I neither have the key nor anything else, I am a student and I wanted to download the program because this link is the full version. I guess there is no such thing.
I get sentinel key not error when my computer is not connected to the internet, although the lock light is on, the program does not open.
"hewaye":2gdl3m5t" said:
I get sentinel key not error when my computer is not connected to the internet, although the lock light is on, the program does not open. /quote] Install the 8 version of the team viwer program from the link below and call us. Let's examine the problem by remote access to your computer.
tel:- 0-224-220 67 17
I am neither a key nor anything else, I am a student and I wanted to download and learn the program because this link is the full version. I want to try to learn this program without the key. I downloaded the latest version and the 7th version, I get the same code, I'm waiting for urgent help
"Bilal Selçuk":i4y8l2vb" said:
I am neither a key nor anything else, I am a student and wanted to download and learn the program because this link is the full version. I want to try to learn this program without the key. I downloaded the latest version and the 7th version, the same code I am waiting for urgent help
You can download and try ideCAD Steel & Reinforced Concrete 8.62 Demo from the attached link. Demo version does not require a lock.
Hello, I think this topic is not up-to-date, but now I have the same problem, I installed it on a new computer, Idecad reinforced concrete is locked, but it gives Sentinel key not found (H 0007) error.
"muh_ozcan":2zju5cq0" said:
Hello, I think this topic is out of date, but I'm having the same problem right now, I installed idecad reinforced concrete on a new computer, but it gives Sentinel key not found (H 0007) error, what needs to be done? ]
There is an answer to your question in the frequently asked questions topic in this forum. 13) Sentinel HASP key not found (H0007) error. How can I solve it? This error indicates that the lock that was given to you when you purchased the program could not be detected on the computer you are trying to run the program on. In this case, make sure that the lock is installed on the computer. Make sure that the light is on. Test your lock on other ports on the computer to see if the USB port that the lock is plugged into is faulty. If your ports are working and you still get the same error, the lock driver is probably disabled has been excluded. Download and reinstall your lock driver
. Some virus programs prevent the installation of such programs. In order to avoid such a problem, we recommend that you disable your virus program before starting the installation.
