HakanŞahin
Administrator
Dear Users, You can download the 8.62 version from the following link:
Log in or register now.
ideCAD Static 8.62 Jobs Done : 1. The program was breaking when the status floor was deleted in a project. Fixed. (beta group Suat Yıldırım) 2. There was a missing Ace warning in raft reinforcements, but there was no warning in the report. Fixed. 3. Empty lines were appearing in the Customize/Customize shortcut/Settings script. Removed. 4. Links phrase that appears in idetotekla Turkish exe has been changed to Joins. 5. When the length unit was changed from m to cm in the retaining wall and well foundation report, the existing As unit was also changing. Fixed. 6. 'Change object layer' was not available in the drawing window in the ribbon menu. Fixed.(forum-mkrts88) 7. Zoom commands added in Ribbon menu. (forum-aydın) 8. ideCAD Static About was displayed in the about section of the Architectural ribbon menu in the upper right corner. Fixed it to appear about ideCAD Architecture. 9. A link was being made from the low-level BP07 basement curtain to the nodal point of the upper beam. Fixed. (say beta isa) 10. It was not possible to enter the tile in the place marked in the attached project. Fixed. (Beta grub-Basri Akyıldız) 11. ideCAD Wrep All scan types were not working by entering polygon. Fixed. 12 Could not specify area with Area command in ideCAD Wrep. Fixed. 13. Unable to click second point in ideCAD Wrep offset command. Fixed. 14. In the project, after converting the spring elements to the curtain, ctrl+z was thrown out of the program. Fixed. 15. The program was closing when I was doing analysis on a project. It has been fixed. (Fatih Caliskan's project) 16. The borders of the D01 tile marked in the picture in a project were formed incorrectly. It has been fixed.(forum-yunussacikk's project) 17. In a project, the effective R mass was getting negative values in the last 3 mods. Fixed. (Beta group-Isa Sayın) 18. When you select the raft tile and click on the 'Draw Similar Object' line from the right-click menu, the program switches to the mold plan mode. Fixed. 19. The unit of the wall load of the beam indicated in the info box was incorrect. Fixed. (Selahattin Bektaş) 20. When we clicked the tile and raft tiling command in a project or tried to enter the properties of the existing tiles, the program would break. Fixed. (Kübra Ay's project) 21. When loading a project, the program was closing. Fixed. (Suat Yıldırım) 22. In a project, vertical continuity was not provided between the 3rd basement and 2nd basement floors in the bulkheads between S7-S14 columns. Fixed.(forum-furkizbey's project) 23. A project was opening very slowly. Now it boots normally. (Hakan Güvengiz's project) 24. The 'Filet' and 'Chamfer' commands could not be accessed in the ideCAD Wrep program. (Beta Grup-Basri Akyıldız) 25. It was not used in soil stress control of 0.9G+E(Earthquake) loads. It had to be used. Fixed. (Erdemli Proje-Melih Bey) 26. When the Reinforced Concrete Design results are displayed in the perspective window, clicking on the INSUFFICIENT (red) shell elements (curtain and raft) did not open the reinforced concrete menu. It has been fixed. (Beta Grup-Basri Akyıldız) 27. After creating the basement floor D05 - ground floor D04 tiles in the Example_2 project, the geometry of these tiles would be distorted when entering and exiting the properties of any slab. It has been fixed.(Beta Grup-Basri Akyıldız) 28. In a project, the meshes of the RD02 raft flooring were not formed. Fixed. 29. Although there was no warning for the B(Joint Shear Safety) problem in the column reinforced concrete dialog and in the report, it was giving a warning in the Analysis model. Fixed. ( İlker Abbas Kargın, Ünver Özcan) 30. TA-TB values were printed incorrectly in the newly added Analysis Settings Summary Report. Fixed. (Basri Akyıldız-Beta Grup) 31. It was not possible to delete raft flooring reinforcement axles in the ribbon menu. It can now be deleted. 32. When we received the pattern plan, the Pattern/Foundation Plan Section command was not visible in the ribbon menu. Fixed. (Forum-Erhan Mollaoğlu) 33. There was inconsistency between the poses of the longitudinal reinforcements of the circular column. Fixed. 34. Beam lines were not visible in sections enclosed in a revision cloud in a project. It is now visible.(forum_aydın) 35. There was a display error of the tread depth condition in the Rib Floor Preliminary Information Report. Fixed. (Statement by Erhan Mollaoğlu) 36. In a project, the punching force and punching strength were not calculated for S39-S40 columns. It has been fixed. (Ömür Yüksel's project) 37. In some projects, foundations on different floors were connected to each other with rigid arms. Fixed. 38. Live loads entered into the raft flooring were not taken into account in the foundation solution independent of the superstructure. The substructure took into account when the superstructure dissolved together. Fixed. 39. Although the Ø12 diameter selection was canceled for the body reinforcement on a continuous basis, Ø12 diameter was selected when opened again. Fixed. 40. In the classic menu layout; Draw concrete calculation axis, linear slab load and point slab load commands have been added to the draw>Object>Rat foundation menu. 41. Move raft slab writing, draw reinforced concrete calculation axis, edit reinforced concrete calculation axis, change reinforcement calculation axis geometry commands have been added to the raft basic toolbar. 42. In a project, when I opened the project, deleted the floors and reopened the project, the program was closed. Fixed. 43. In the Ribbon Office 2007 Black Style selection, the layer names were written in white and the text was not visible. Fixed. 44. Click the OK button to delete all floors except the ground floor in a project, the program was closing. Fixed. 45. The curtain finite elements were getting longer in a project. Fixed. 46. In a project, the program was breaking when getting the symmetry of all objects on the perspective screen. Fixed. 47. In a project, raft foundation finite elements were formed incorrectly in the direct connection method. Fixed. 48. The analysis menu on the tab in the ribbon was made in the same order as the analysis menu on the reinforced concrete tab. ideCAD Static 8.61 Possibilities: 1. Ribbon Menu layout has been added. The ribbon menu can be selected from Settings/General Settings. 2. Reinforced concrete calculation according to ENV 1992-1-1 Eurocode 2, taking into account the in-plane stresses of shells, shear walls and floors (semi-rigid slab reinforced concrete calculation according to the new regulation) 3. Semi-rigid diaphragm analysis system was redeveloped in accordance with the 2017 earthquake code. 4. Fixed issue with finite element meshing of floor tiles and curtains. 6. As in Tekla, the 'clip' feature has been added in 3D on the perspective screen. 7. User defined downloads are now printed in the Downloads and combinations report. 8. Transfer to Sap2000 program has been added again. 9. Problems related to connecting inclined slabs to columns, curtains and floors have been fixed. 10. Select button has been added in the shear reinforced concrete dialog, as in the column reinforced concrete dialog. 11. It has been shown as an option in the stair formwork plan. Cross-sections of the stairs in the formwork plan can be taken. 12. Added the ability to move structures in 3D perspective. 13. Added raft and raft edge command. 14. Beam, slab edge, raft, etc. Removed the requirement to change architecture mode-pattern plan mode or vice versa when entering. 15. Improved ideCAD Wrep possibilities. 16. Drawings and transitions between floors have been simplified. Features Made in ideCAD Static 8.504: 1. Modeling of rafter raft foundations according to finite elements together with beam, plate and superstructure 2. Raft foundation by defining continuous foundation only from outer frame 3. To be able to monitor the moment shear force diagrams of continuous foundations without visualization 4. Modeling of continuous foundations as T beams 5. Beam-beam, continuous foundation-continuous foundation, panel-beam etc. In divisions, the element division algorithm has been improved according to the carrier-bearing element relationship. 6. General improvements have been made to column-foundation beam connections for continuous foundations. 7. The flooring under the columns in raft foundations seemed to be cut visually. Now it looks whole. 8. Giving the controls in the retaining wall reinforced concrete dialog 9. Reinforcement deficiencies were not shown in red in the column reinforced concrete dialog, they are now displayed. 10. According to version 7, rib beams were not shown in the cross section of the formwork plan. It is now showing. 11. In the Risky Building Analysis, polygon column dimensions appeared as rectangles in the critical Floor column limit values report. Adjustments have been made for circle and polygon column dimensions. 12. The beamed raft was basically perceived as negative stress by printing negative G and Q in Reports. Absolute value is now printed. 13. When a rigid diaphragm is detected, a warning is given as Rigid Diaphragm-1 Rigid Diaphragm-2 instead of RD1 RD2. 14. The Risky Building Analysis command has been added to the Analysis menu. 15. Gradient background color selection 16. ideCAD Wrep 8 17. 3D Printer model output capability has been improved 18. Entry of elements that meet the curtain condition only with the panel command 19. Risky building code 3.5.6. Added check item. Options Made in ideCAD Static 8.1: 1. Adjustments, improvements and accelerations were made in navigation and flight mode on the 3D screen. 2. The selection process in the 3D screen has been accelerated, the intersection selection mode has been added. 3. Added the possibility of modal analysis with Ritz vectors. 4. Arrangements have been made in object grouping (selection groups), the right button has been made easy to use from the menu. 5. Added the ability to draw elements with full body in the analysis results visualization. 6. Added the ability to display deformations with a colored scale in the analysis results visualization. 7. Added optional "hot zone scale" in analysis results visualization. 8. Added a feature that shows the location of the problematic node on the 3D screen, in case the analysis cannot be performed as a result of the system matrix not being reduced. ideCAD Static 8.029 Possibilities: 1. Column reinforcements are automatically equalized on lower floors if more of them are on the upper floor. 2. Added visualization of critical wall height to reinforced concrete visualization options. 3. The hooks of special earthquake crossties are drawn in a staggered manner. (A. Hardallı) 4. When the + sign in the building tree is clicked, the bottom lines would not open. It opens. 5. Vertical loadings for the raft foundation are now visible on the 3D viewing screen. (Erdemli ) 6. When the beam is checked for conformity torsion, the torsional stiffness of the beam is now taken as zero. opportunities Made in ideCAD Static 8.028: 1. The report number is no longer printed in the reports except for the risk building analysis reports. 2. Analysis settings summary information report has been made. 3. Reinforced concrete design and analysis settings report was made.
