ideCAD Static 8.504 update
HakanŞahin
Administrator
Hello there ; Version 8.504 is now available. Studies have been carried out on the errors identified in 8.503. Reinforced concrete possibilities and improvements according to 8.103: 1- Modeling of rafter raft foundations according to finite elements together with beam, plate and superstructure 2- Making raft foundations by defining a continuous foundation only from the outer frame 3- Moment shearing force of continuous foundations diagrams without visualization 4- Modeling of continuous foundations as T beams 5- Beam-beam, continuous foundation-continuous foundation, panel-beam etc. In divisions, the element division algorithm has been improved according to the carrier-bearing element relationship. 6- General improvements have been made regarding column-foundation beam connections for continuous foundations. 7- In raft foundations, the flooring under the columns seemed to be cut visually. Now it looks whole. 8- Giving the controls in the retaining wall reinforced concrete dialog 9- In the column reinforced concrete dialog, reinforcement deficiencies were not shown in red, they are now displayed. According to version 10-7, rib beams were not shown in the cross section of the formwork plan. It is now showing. 11- In the Risky Building Analysis, polygon column dimensions appeared as rectangles in the critical Floor column limit values report. Adjustments have been made for circle and polygon column dimensions. 12- Beamed raft basically, negative printing of G and Q was perceived as negative stress in Reports. Absolute value is now printed. 13- When a rigid diaphragm is detected, a warning is given as Rigid Diaphragm-1 Rigid Diaphragm-2 instead of RD1 RD2. 14- The Risky Building Analysis command has been added to the Analysis menu. 15- Ability to choose gradient background color 16- ideCAD Wrep 8 17- 3D Printer model output capability improved 18- Entry of elements that meet the curtain condition only with panel command 19- Risky building code 3.5.6. Added check item. Visual C++ Redistributable Packages for update 3 (version no: 14.0.24.12.0): Microsoft c++ 2015 plugin also needs to be updated to version 14.0.24.12.0 during the update. The installer provides the installation of version 14.0.242212.0 of the Microsoft c++ 2015 plug-in. However, against possible problems, you can download the add-ons from the link below and install them yourself.
You can use this version with confidence. With the semi-rigid diaphragm option, some problems may still occur in the solution. The earthquake regulations in force do not require calculation with semi-rigid diaphragm anyway. With the 2016 earthquake regulation, semi-rigid diaphragm will become mandatory. Note: All problems with Semi-Rigid diaphragm option have been fixed and version 8.61 has been released. You can download it from the following link:
"saridurmus":1kqsgou6" said:
Is the demo of version 8.504 out
Hello Ibrahim, demo version 8.504 is not out yet, but installations are being prepared. It will be announced on the forum when it becomes available after installation tests. Good work
"Ismail Hakki Besler":15tfyzdc" said:
You can use this version with confidence. Some problems may continue to arise in the solution with the semi-rigid diaphragm option. The earthquake regulation in force does not require calculation with semi-rigid diaphragm anyway. 2016 earthquake regulation makes semi-rigid diaphragm mandatory.
Could you elaborate on what kind of problems occur in the semi-rigid diaphragm solution?
"kyuceturk":19zdv0eu" said:
"Ismail Hakki Besler":19zdv0eu" said:
You can use this version with confidence. With the semi-rigid diaphragm option, some problems may still occur in the solution. The earthquake regulations in force do not require calculation with semi-rigid diaphragm anyway. With the 2016 earthquake regulations, semi-rigid diaphragm will become mandatory.
Could you elaborate on what kind of problems occur in the solution of semi-rigid diaphragm? Thank you
Problems may arise in creating tiled finite element meshes. You can understand this situation by examining the finite element meshes and whether there is a problem. Note: All problems with Semi-Rigid diaphragm option have been fixed and version 8.61 has been released. You can download it from the following link:
I encountered some problems in the detail drawings of the continuous foundations that I defined under the panel. In the drawings he mixed the foundations on the left and right of the panels. The program was 8.103. Then I installed 8,504 but the result did not change. In architecture, there are no columns at the ends of the panels. After the reinforcement was piled up, I turned that part into a raft foundation and solved it. I am writing in case you encounter it in another project. I manually added the title to the stand-alone panels of that size. The program solved it without a title. In some municipalities, there may be hang-ups or problems.
"Tombombadil0785":qfkonpk8" said:
I encountered some problems in the detail drawings of the continuous foundations that I defined under the panel. In the drawings, I drew the foundations on the right and left of the panels in a mixed way. The program was 8.103. Then I loaded 8.504, but the result did not change. In architecture, the column was drawn at the ends of the panels. It doesn't exist. Due to the piling up of the reinforcement, I then turned that part into a raft foundation and solved it. I'm writing it in case it comes across in another project. I added the title to the stand-alone panels of that size manually. The program solved it without a title. In some municipalities, there may be hangups or problems.
Can you add the projects to our review for.
"Ismail Hakki Besler":vog143sy" said:
"Tombombadil0785":vog143sy" said:
I encountered some problems in the detail drawings of the continuous foundations that I defined under the panel. In the drawings he mixed the foundations on the left and right of the panels. The program was 8.103. Then I installed 8,504 but the result did not change. In architecture, there are no columns at the ends of the panels. After the reinforcement was piled up, I turned that part into a raft foundation and solved it. I am writing in case you encounter it in another project. I manually added the title to the stand-alone panels of that size. The program solved it without a title. In some municipalities, stuttering or problems may occur.
Could you add the projects for us to review.
After converting that part to a raft foundation, I deleted the file. I'll PM you another time.
Hi, I regret that I have installed the idecad 8.504 version, my computer is overheating and I think I will re-enter a very heavy project (800m2 based and 4 floors) that I drew in ide 8.103. After pressing the report button, the computer gives a "not responding" warning and then itching It opens in a way. When I register to the lower version 7.020 from the program, all floors and beams give an error. They have officially made ide 8.504 mandatory. I haven't entered a project from scratch in 8.504 yet.
"civilengineerhakan":2g42xpjh" said:
hi, I regret that I have installed idecad 8.504 version, my computer is overheating and I think I will re-enter a very heavy project (800m2 based and 4 floors) that I drew in ide 8.103. After pressing the report button, the computer ' It gives a 'not responding' warning and then opens in a way that stutters. When I register to the lower version 7.020 from the program, all floors and beams give an error. They have officially made ide 8.504 mandatory. I haven't entered a project from scratch in 8.504. I hope it doesn't do the same thing, If it does, I will forcefully return to 8.103.
Hello, there is no performance problem in 8.504. If you add the project you have performance problems, we will examine it. We can also connect to your computer with remote access and look at it together. The necessity of splitting elements has been removed to facilitate data entry in joints such as slab edge, etc. If you transfer data from 8.504 to 7.020, the element intersection You should rearrange them according to the data entry rules of 7.020. For remote access: Install the following program before calling:
Bursa office: 0 224 220 67 17
In fact, on the contrary, since we switched to 8.504, we have been using it without any problems and with full efficiency, but I am very satisfied, even if there are minor problems.
WHEN I WANT TO OPEN THE PROGRAM AFTER INSTALLING, IT GIVES THIS ERROR. CAN YOU HELP ME ? HAS ANYONE ENCOUNTERED BEFORE A PROBLEM?
