ideCAD Static 8.504 Old Version
HakanŞahin
Administrator
ideCAD Static 8.504 Old Version (01.09.2016) Revisions Made in Transition from 8.103 to 8.504: 1- Element design with TS EN 1993-1-1 Euro code 2- TS EN 1991-1-4 Calculation of wind loads with Euro code 3- New Steel Regulation 2016 published in the Official Gazette, Design of Elements and Steel Joints 4- Scaffolding Macro 5- Cover joint for Box/Pipe profiles 6- Joint with stiffened butt plate for weak direction 7- Truss plate with butt plate 8 - Front plate truss combination for Box/Pipe profiles 9- Seating truss junction 10- Crane joint 11- Sub-plates can be angled in ridge joint 12- Separate layer for secondary steel beams 13- Console element combination has been made more suitable for cranes. 14- Work was carried out to create plan drawings, point details, facade drawings in steel drawings, and to reduce interference with simplification in steel drawings. 15- Steel column-single foundation drawings 16- Length, weight, etc. given in the layout table in the steel drawings. displaying the units of the values 17- Self load of the composite slab was not transferred to the system. Transferring. 18- Since metal floors do not exhibit rigid diaphragm behavior, the program does not create a rigid diaphragm for them. 19- Open/Close purlins in 3D Filter Reinforced concrete possibilities and improvements: 20- Modeling rafter raft foundations according to finite elements together with beam, plate and superstructure 21- Making raft foundation by defining a continuous foundation only from the outer frame 22- Monitoring the moment shear force diagrams of continuous foundations without visualization 23- Modeling of continuous foundations as T beams 24- Beam-beam, continuous foundation-continuous foundation, panel-beam etc. In divisions, the element division algorithm has been improved according to the carrier-bearing element relationship. 25- General improvements have been made regarding column-foundation beam connections for continuous foundations. 26- In raft foundations, the flooring under the columns seemed to be cut visually. Now it looks whole. 27- Giving the controls in the retaining wall reinforced concrete dialog 28- In the column reinforced concrete dialog, reinforcement deficiencies were not shown in red, they are now displayed. According to version 29-7, rib beams were not shown in the cross section of the formwork plan. It is now showing. 30- In the Risky Building Analysis, polygon column dimensions appeared as rectangles in the critical Floor column limit values report. Adjustments have been made for circle and polygon column dimensions. 31- Beamed raft basically, negative printing of G and Q was perceived as negative stress in Reports. Absolute value is now printed. 32- When a rigid diaphragm is detected, a warning is given as Rigid Diaphragm-1 Rigid Diaphragm-2 instead of RD1 RD2. 33- The Risky Building Analysis command has been added to the Analysis menu. 34- Ability to choose gradient background color 35- ideCAD Wrep 8 36- 3D Printer model output has been improved Correcting the errors identified in 37-8.500 Visual C++ Redistributable Packages for update 3 (version no: 14.0.24.12.0)[ /b]: Microsoft c++ 2015 plugin should also update to version 14.0.24.12.0 during the update. The installer provides the installation of version 14.0.242212.0 of the Microsoft c++ 2015 plug-in. However, against possible problems, you can download the add-ons from the link below and install them yourself.
Re: ideCAD Static 8.504 update Hello. Now, as in the past, if we download the idecad 8.504 version, wouldn't it be better if we install it directly and not wait for the old versions to be installed. Also, a separate installation file is required for steel and reinforced concrete. It would be nice if friends like me with 2 reinforced concrete locks and 1 steel lock finished the installation with a single file. Now I am installing ide8 reinforced concrete on a computer and steel on a separate one. I need to download a separate update for my technical friends using my reinforced concrete lock. I have to download it separately for myself and it's a separate problem to archive the files I downloaded, it's confusing when I say which is the update of steel and which is concrete, then come on... the most interesting thing is that I can't switch to 8.103 without installing 8.030, then I have to install 8.504. I encountered a problem. It was the installation file of the steel version I had. I struggled for 1 day. Your technical team warned me, thanks, let's solve this problem.
"Apocalpyse":3dgzmxqo" said:
Hi there. Now if we download the idecad 8.504 version as before, wouldn't it be better if we didn't wait for the old versions to be installed, but also for steel and reinforced concrete. A separate installation file is required. It would be nice if friends with 2 reinforced concrete locks and 1 steel lock, like me, finished the installation with a single file, now I am installing ide8 reinforced concrete separately on a computer and steel separately for my technical friends who use my reinforced concrete lock, I need to download a separate update for myself. I need to archive the files I downloaded and it's a separate problem. It's confusing when I say which is the update of steel and which is concrete, then come on... The most interesting thing is that I can't go to 8.103 without installing ide 8.030, then I need to install 8.504. In the current situation, is it my fault? I encountered such a problem in the previous update. It was the installation file of the steel version, I struggled for 1 day, your technical team warned me, thanks Please let's solve this problem.
No, you don't need to install them separately. 8.504 is a single installation. You can download and install directly. (It doesn't matter if it is reinforced concrete and/or steel). Also, you don't need to have the old version installed on your computer.
Re: ideCAD Static 8.504 update when I get a report, the left and right connection parts are always blank in the old versions. How can I solve this problem? I have attached the picture
Re: ideCAD Static 8.504 update Hello, If you add your project, let's examine it.
"sultanfatih":8p4g9lzs" said:
when I get a report, the right and left connection parts are constantly showing blank in the old versions, how can I solve this problem. I have attached the picture[/ quote]
"sultanfatih":3nf4dbl4" said:
when I get a report, the right and left connection parts are constantly showing blank in the old versions. , - Column names will appear in the Continuous foundation information report when you perform analysis by ticking the "superstructure interactive solution" option in the Analysis Settings / Foundations Tab. Your statement will be corrected in our notes and in the next version. Good work
Re: ideCAD Static 8.504 update It shows connected until 18, then it's blank again. Although it gives errors in other versions, it shows that there is no problem in this version.
"sultanfatih":37ujnwkz" said:
It shows connected until 18, then it's blank again. Although it gives errors in other versions, it shows that there is no problem in this version, it needs to be fixed urgently, thanks.
When the superstructure interactive solution is made, the right ends of the TK18-TK19-TK20 continuous foundations are shown blank as both ends of the TK21-TK22 continuous foundations are connected to the foundation. This was how it was shown in previous versions. Good work
