mehmet2015
The program is running very slowly, I reset it, but it did not improve. my pc specs; ram 6gb intel-i5 2.6ghz win 10
install 64 bit version ideCAD Static 7.022 64 bit full cd download :"mehmet2015":fgjmidse" said:the program is running very slow, I reset it but it didn't improve. my pc specifications; ram 6 gb intel-i5 2.6 ghz win 10
1. Click on Settings/General Settings 2. Activate 3D drawing mode and Disable Show 3D primitive objects. If the problem persists after the above steps, the problem is related to your graphics card performance. Nvidia graphics card is required to work efficiently in 3D. If your card is not opengl supported, you can disable the Use OpenGL hardware accelerator option at the same place. You may still have problems with performance. Onboard graphics cards fail opengl operations. Get a graphics card with Nvidia chip. If you have an Nvidia chip graphics card, make sure you have the latest drivers installed. System requirements for version 7: Intel core i5-2500 /AMD phenom II X4 975 or higher processor (Intel i7-2600 recommended) 8 GB RAM (12 or 16 GB recommended) 32/64 bit Windows Vista or Win dows 7 operating system (64 bit Windows 7-10 recommended) Nvidia GeForce GTS450 or higher graphics card (GTX 560, Quadro 2000 or Quadro 4000 can be considered as better options) 1920x1080 monitors are now recommended because they are cheaper. Intel Core i5-2410M or higher processor for laptop (core i7-2630QM recommended) 8 GB RAM (12 or 16 GB recommended) 32/64 bit Windows Vista or Windows 7 operating system (64 bit Windows 7 - 10 It is recommended for CAD work because the opengl support of the nvidia series cards is more successful, although the external Nvidia graphics card can be worked with ATI graphics cards in the program."mehmet2015":aoaajdxl" said:I have the same problem when entering data, examining 3D images or trying to do anything with the mouse.
