ideCAD Static 6.50 Beta new version
HakanŞahin
Administrator
Dear users, you can download the ideCAD Static 6.50 beta (trial) version from the link below.
The file in the link is the full cd content. ideCAD Static list of works and possibilities in version 6.50: 1. New beam expansions - Expansions of inclined beams - Measuring the transition lengths of the reinforcements in beam expansions according to the axis system - Displaying the beam elevations as an option - Creating the cross-section lines for each beam opening in the beam opening and drawing the beam sections - Making suspension reinforcement drawings in the inserted beam area - In the beam settings; Options for reinforcement transition conditions and bending for beam extensions - Showing the reinforcements in beam sections with their pose numbers - Measuring the overlap lengths in reinforcement joints - Automatic overlapping when the maximum reinforcement length is exceeded in single span beams - In similar floor beam drawings, changing between floors Also showing the pleat, flat and stirrup reinforcements 2. Writing the project, drawing, detail and opening and 3D project data to PDF file. Thus, the possibility of examining the project by others without a program - Optionally transferring the 2D details and drawings in the project with pen thicknesses - Transferring the 3D model separately and examining it in 3D in the pdf file - Writing the whole project as pdf - Transferring the plans and drawings in the pdf file with indexing and easy access to floor plans and details in a pdf file -Transferring drawings with the choice of architectural or formwork plan mode 3. New performance analysis system and reinforcement reports - Performing performance analysis according to the minimum performance target foreseen for the building - Programming the probability of exceeding the earthquake for the targeted performance level - Performing 2-stage non-reinforced and reinforced structure analyzes one after another automatically, in one go. Ability to perform performance analysis of the building - Optional retrofit reports dialog - Dialog listing of calculation stages during performance analysis - Existing structure/reinforced structure comparison reports; existing structure/reinforced structure displacements; floor forces; floor information; earthquake parameters etc. reports - Element ductility checks; Explanations on whether the element is brittle or ductile in the report - Indication of the cause of element damage in the performance report - Option whether to consider crossties in the calculation of the column Vr shear force 4. TS498 Article 13 Application of Live Load Reduction 5. Automatic naming possibilities especially for elements in different rigid diaphragms - Ability to give names from the beginning in automatic naming - Ability to store names used after object naming -Curtain-size columns in one direction option for naming or naming separately for x and y direction 6. New reinforced concrete configuration tab in Beam Reinforced Concrete dialog. -With new look; drawing the beam expansion in the dialog -Tracking the missing and redundant reinforcement areas -Monitoring or applying information such as whether the reinforcement is bent, combined or partial transition can be made on the supports 7. New user defined element loads report 8. Displaying the beam-column joint shear safety calculation details in the column reinforced concrete dialog 9. Display of deflection and crack control calculation details in beam reinforced concrete dialog 10. Ability to find and select an object selected in the plan in perspective view with "Find in perspective" command 11. Complete stirrups in beams option to tighten 12. Option to perform full stirrup compaction in columns 13. Automatically giving floor indices when floor is defined in floor general settings 14. 3D block import/export 15. In general settings; Anti alias possibility to show object edges properly in perspective images in 3D working windows 16. Ability to give the same slope to more than one object (floor, beam) at the same time. Thus, the possibility of entering inclined slab/beam systems much easier 17. The ability to change the compaction length value of the lower part of the column 18. Automatic consideration of sub-basement walls in the calculation of column length (ln) and lower compaction zone length 19. When a basement curtain is connected to the column; In column shear safety control, the remaining column clear length from the height of the basement curtain should be taken into account 20. In the general report of the earthquake regulation, the R coefficient is suggested under the necessary conditions. 21. Changing the length of the header region on curtains. With this opportunity, the length of the headboard area of the curtain can be changed on all floors and indirectly the critical curtain area can be changed. 22. The ability to define a header area if desired in panels that do not require a header area according to TDY 23. Ability to define different rigid basement floor numbers in X and Y directions 24. Automatic section taking in formwork and foundation application plans - Taking sections in formwork or foundation application plans - Changing the section line properties - Marking the section line and renewing the section - Creating the desired number of section lines - Moving the section line and renewing the section according to the moved place 25.[/ b] Integration with OSKA progress payment program -Reading unit exposure lists -Transferring project quantity and accounts 26. Integration with AMP progress payment program -Reading database from AMP -Transferring project quantity and accounts 27.[ /b] Ability to automatically turn off the properties of layers, drawing settings, etc. in the project with one click with the "Make architectural/statically compatible" commands 28. "Find an object selected in the plan in perspective" command Ability to find and select in perspective view with u 29. Option to see only architectural or formwork plan objects while working in perspective window 30. Black and white hidden line and border line solid model options for perspective display formats 31. Ability to apply image configuration to all floors 32. Option to display "material name" together with "description" in building components 33. Align and distribute commands
I am very happy to work with IdeYAPI. I would like to thank the esteemed ideYAPI family for constantly developing this program, being there for us whenever we call, and giving the opportunity to get to know our esteemed colleagues and their practices, especially by offering this forum environment. Cengiz Aydogan
hello, I tried to install version 6.5 but I couldn't. I think the hasp file is missing, I would be glad if you could help. good work.
Hi, it works with 6.5 beta version 6 hasp. If you are not a version 6 user, you will get a hasp error.
"ciyamee":1j9vdg6j" said:
hi, I tried to install version 6.5 but I couldn't. I think the hasp file is missing, I would appreciate it if you could help. Good work.
I solved the last project I have with 6.5 and I have to say that when we change the beam details and automatic sectioning from the properties, it would be nice to change the name of the section in the plan. The names seem to be intertwined in similar beams in multi-storey buildings, once again, it's still the best static program on the market, İde
"siromar":y074h612" said:
When we change the section names from their properties, it would be nice if the name on the plan changes, for example, when we make the section AA from the features, the section line becomes AA but the section does not change, we explode and change it, it's not a difficult thing, but just a suggestion
Hello, For example, 1-1 section You have changed the definition of the section line. Then mark the relevant section line on the plan and press the right mouse button. Click the "View section" line in the menu that appears. Recreate the section and place it on the plan. This way, you will not need to explode the section block. You can delete the old one later. Take it easy...
Greetings, While drawing the curtain reinforcements, the horizontal one of the reinforcements ending in different levels is incomplete. It would be good to show this different jeans at once.
First of all, I would like to congratulate you for your work. I installed the 6.50 Beta version, I can do everything easily, but when I want to look at the beam expansions, the program gives an error and closes. Is it because it is the beta version? I am using windows 7 operating system. I'll be pleased if you pay attention.
"dester":2kkxeks3" said:
but when I want to look at beam expansions, the program gives an error and closes. Is it because it is beta version? I am using windows 7 operating system. I would be glad if you are interested.
As I said before, when I wanted to get the beam expansions, it gave an error. it gave the same error in my other work before. the file is attached.
Enter the offset of the K48 beam as 15.01 cm instead of defined=15, the program will not be closed when the beam is opened. You will not need such a change as precautions will be taken in the new beta update. You can add other projects that you have problems with to the message. Good work... Note: The project I made changes is attached.
Mr. Hakan, I also looked at the project, but I could not get the beam drawings even though I changed all the beam misalignments on that floor one by one and made the definitions of t=15 ones as t=15.01.
"saridurmus":1lqb434m" said:
Hakan Bey, I also looked at the project, but I couldn't get the beam drawings even though I changed all the beam misalignments on that floor one by one and made t=15 to t=15.01.
I added the corrected project to the previous message. .. you can look there
