ideCAD Static 6.2007 Update (06.10.2010)
HakanŞahin
Administrator
Dear Users, You can download the ideCAD Statik 6.2007 program using the link below:
List of works done: 1 . Geometry control has been improved for various data entry errors that give the message "The system cannot be resolved" in the analysis. 2. An option to set the column condensation zone length as 1.5Lb has been added to the column parameters. When the option is checked, the compression length is 1.5Lb, when it is not selected, the compression length is adjusted according to the conditions of Bmax , ln / 6 and 500 mm. 3. The possibility of intervening on floor-effect cutting areas in floor parameters has been introduced. The values that can be entered as +Aw and +Ag allow adding or subtracting values on existing values. 4. Added column-beam shear safety control for interfloor beams. 5. After saving the reports as pdf, the resolution of the logo added to the report does not change anymore. Good work
