ideCAD Static 6.2006 Update (04.08.2010)
Status
Not open for further replies.
HakanŞahin
Administrator
Dear Users, You can download the ideCAD Statik 6.2006 program using the link below:
List of works done: 1 . No matter how the column and screen are placed, writing the horizontal dimension as the first dimension has been put as an option in the Settings/General Settings/Drawing tab. 2. The report file saved as pdf is now created in a smaller size. 3. It is possible to select ribs or cassette lines as blocks in the pattern plan and can be selected at once. 4. Cloning and pasting of library objects caused by closing the program has been fixed. 5. The program closing situation that occurs after the base point is given by using advanced capture (ctrl) while drawing a vault has been fixed. 6. The situation where the warning message given during the execution of the 2D architectural project read command could not be turned off has been fixed. Good work
Status
