Hello. One of the most important issues in static project drawing is to ensure full synchronization with the architectural project. In this context, the static project can also be controlled in 3D via the 3D drawing program sketch up, which is widely used by architectural offices. Attached is an example of the dwg file exported from İde with the export dwg command, imported by the sketchup program. During this process, there is no need to open the dwg file in autocad, it can be directly imported into Sketchup. Architecture - I wanted to share it because I thought it would be useful in terms of static compatibility and auditing. Good work
