ideCAD reinforced concrete column beam joint point
lilahmiharbi
When connecting beams to columns in idecad reinforced concrete 7 program, do we have to connect them at the nodal point of the column? sometimes when connecting the beams, the nodal point of the column does not coincide (in small projects, we pass the axles right around the corner so that it can be applied easily on construction sites). When I check from the frame system, all the beams are connected to the columns. As I said, an incorrect data attempt is made in the binding made without coinciding with the node of the arm
"lilahmiharbi":3255omn2" said:
in idecad reinforced concrete 7 program, do we have to connect the beams to the columns at the nodal point of the column? Sometimes when connecting the beams, the nodal point of the column does not coincide (in small projects, we pass the axles right around the corner for easy application on construction sites). all the beams are connected to the columns.As I said, erroneous data attempts are made in the connection made without coinciding with the nodal point of the arm
No, it is not necessary, you will not have entered wrong data.
