hello guys, I can't fix the report errors in the attached static project. Can you help me? It's an urgent situation. Thank you in advance.
[ /quote] Dear byfrudo, first of all, do not put the .bak file in your zip file, you have doubled the upload file size for no reason * S26 column and S29 column on the ground floor do not overlap with the column above.
Geometry check , you will see it. Column dimensions Entered differently * If you increase the console parts of your raft floor a little, you will solve the raft foundation problem (eg 1.5 m after the column) * Did you mark your circular columns on the balcony as
free columns on the balcony. If you are going to solve it with beamless flooring logic, [ You must select b]semi-rigid diaphragm[/b], then check the box
Consider earthquake effects on slabs * You may need to change the orientation of some columns, because
columns It does not provide join-safe. Maybe you should arrange some of your columns in a square or that way. *
You entered -1 as the upper rigid basement floor number , but there are no rigid perimeter curtains in your basement. Then you need to enter -2. In addition, if I have to say with their names on the ground floor, the columns S26, S29, S34, S36 were not elongated enough to press on the beams. The beams are halfway down. Shouldn't your balcony floors have a live load of 0.5? Your curtain amount is low and its contribution to the system is very low. But maybe if you edit the column sizes, you can solve the curtain problems. Did you deliberately design the K19 50/60 beam in the basement in this way? Your columns are not sitting on the axles. This will cause your drawings to be smooth (especially the column application plan) not smooth. (It is not a matter that will affect the calculations.) I did not have the opportunity to examine it much, these are the first ones that caught my eye. Good luck with.....
