cem_kucuk569
I have been working from ideacad training videos, but the number of beam and column reinforcements there is not enough.
Hello, If you add the project you compared with the project you made in the demo to the message, we can examine why the results are not the same, we can write a clear answer."cem_kucuk569":8bn6m3iw" said:hello, I did the same project in the training video, but the results are not the same, it's too exaggerated
check the column, beam and slab loads..it's probably giving the error there. once again. good work"cem_kucuk569":12i7sdoj" said:hi I did the same project as in the training video, but the results are not the same, it's too exaggerated
