Erman Güdü
How can we define the İdecadde basement curtain?
I agree with what Mr. cassabotanic said.. The correct method is important, can we show the correct inundation method with a sample drawing.."cassabotanic":2wqruypt" said:The fact that the basement curtains are not included in the calculation will result in erroneous results. After the basement curtain, the ground floor continues at normal level. If you do not enter the basement curtains into the system, you will enter the ground floor 1 - 1.5 meters higher, or the ground floor You will start from the top of the basement. Both options are not the right model. If you build the basement walls with 5-10 cm joints to the columns, what you said is valid. In this case, the ground floor ceiling will make unnecessary displacement due to the extra growing ground floor ceiling level. The columns that will take extra horizontal load will be forced unnecessarily. The duly designed and built basement curtains both relax the system and thus you model your structure in accordance with its behavior.
Hello, there is no error message in the program that the basement floor is not rigid ... The best thing is to add your project... Let's look at your question about the data entry you want to do in your project..."ssesli":38q168ec" said:Hi, I couldn't find any data on this subject. Any progress? I defined a basement curtain at -60 level and defined it as a basement curtain. This time it gives the error that the basement floor is not rigid? What do you think? the way should be followed?
