ideCAD Architecture V7 will be available in the fall. Update to Version 7 is free for 6 version users. ideCAD Architecture V7 features: 1) Displacement mapping facility
	 2) Ability to work on large projects without memory constraints with the 64-bit program version 3) Facilitating project follow-up with the option to draw floors/spaces fully on the plan 4) Manual tiling by defining peripheral elements in addition to automatic tile creation and the possibility of creating zones/defining zones to panels 5) Command line and dynamic input possibilities
	 6) Considering the opacity map value in the grass effect Ability to make partially grassed areas 7) Broken curved axis display option
	 8) Revision cloud object 9) Wavefront .obj files Ability to import/export 10) Close unused layers command 11) Off Ability to offset the axes to the set command 12) Rounding the edges of the box object 13) Using the unformed textures as opacity map with the possibility of reversing the opacity map values 14) Sphere object for architectural general use
