ideCAD Architecture-ideCAD Static
civilng
Good afternoon. When I open a project drawn with idearchitecture in idestatic, the column-beam names do not appear. I also looked at the layer settings, but I could not find a result.
Re: IDEMİMARİ-IDESTATİK Hello, you can make beam and column names visible by using Make Compatible with Static command from Change Menu. You can also toggle the desired layer on the Layer Settings / Drawing Details Tab.
Re: IDEMİMARİ-IDESTATİK How can we make the back of the idearchitecture white and black and the column beam walls are not written on the idearchitecture
"matrax":2jrwk0ub" said:
how can we make the back of the idearchitecture white and black and the name of the column beam walls is not written on the idearchitecture
You can change the background color from the Settings/General Settings dialog .
"Levent Özpak":18a37j2t" said:
Hi, You can change the beam and column names by using the Make Static Compatible command from the Change You can also make the layer visible from the Layer Settings / Drawing Details Tab.
Thanks for your reply, Mr. Levent. My problem is solved. But I can't see the account axis of the tiles at this time. Can we open them too?
