eissenhover
Hello everyone. I had a few questions, if you could help me I would be very happy. 1) In the attached image, the idecad analysis settings page can be seen. Here, there is no option such as "equivalent earthquake load" or "mod combination method" in the earthquake load calculation method section, instead two options by saying "mod contributions of mode contributions ....." and "mode contribution of element-specific results....." there is. What exactly do they mean, how do we choose the equivalent earthquake load method? 2) There are equivalent earthquake and mode combining options as analysis type in the strengthening section of the analysis settings. but the method we have chosen here is in the strengthening section, so I think it is not valid for static analysis, but valid for performance analysis. How do we choose the equivalent earthquake method in static analysis, as I asked in the first question when designing a building from scratch? 3) I also examined the steel regulations, but I was very confused about GKT and YDKT. Do you have any advice about whether we should choose GKT or YDKT when choosing? 4) In the program, for example, I set the values of moment 2 and moment 3 in the freedom part of a fracture to zero. I connect the two ends of the beam to the columns by choosing one of the rigid connections in the program. When I analyze and look at the analysis model, I see that no moment is transferred at the tip of the crease. the program does not recognize the rigid part i made as well?? 5) Finally, in the attached project, there is 1 break that exceeds the deflection limit and a break that does not save the cutting capacity. It gave deflection problem in other beams as well, I saved the wrinkles by splitting them in half. but there is something i don't understand. The length of the creases is already around 5 meters and it presses on the column at almost every 1 meter interval. that is, when the openings in the 5 meter section are 1 meter, how does it give a deflection error. Could you take a look at the project and comment?
