Hello. I am a novice user. years ago, I used the demo version and got the licensed version of the program I liked. and first i faced the following problems. 1) Some dots and lines belonging to the imported .dwg file are not deleted, moved or even selected. 2) I cannot give offset to the l-column I designed with the polygon column editor. Whatever value I enter, the element remains constant. (Is it possible to see the element as a panel since its size is large?) 3) I cannot incline the column on both sides. I bent all the columns in in my attic, but I need to tilt the corner one biaxially, what should I do? suggestion: x/y direction can be inclined separately or options such as upper misalignment/lower misalignment can be developed. 4) Again in the attic floor, I see the inclined column/tilted beam combinations incorrectly in 3-dimensional. Since the column is inclined, the beam touches the end of the shear zone, only the bottom part of it appears to be empty. Could there be an error in the calculations?!!!! 5) Also, for new users like us, we can see the entire account of a 3-4 storey building. but I think it would be very useful if you upload a training video where all the different possibilities and features are used. thanks and good work.
