Hello , In order to help you with the issue, we need to be able to see the process you wrote. For this, you must either add the project, we can see the problem, or we can connect to your computer with remote access and look at the problem together. Because there is no problem with the operation of the command. Before calling us for remote access, install the following program:"kyuceturk":1epjz0fy" said:Hi, I want to name the objects in my project sequentially from the beginning. For this, I select the relevant option and give the naming start shapes (s001, d001 ).There is no change in the project even though it says naming has been done
