Hello, 8.62 latest The project is saved in 8.62 format"unalmh":1somsk18" said:hi, 1) I downloaded version 8.62 but when saving the project it saves in 8.5 format..
Not true. I think you mean the 8.62 version by 8.5, but if not, your friends should use the latest 8.62 version."unalmh":1somsk18" said:2) It is said by friends who use this version that the 8.5 version has too many calculation errors, is this true?
In semi-rigid diaphragm solution, slabs, columns, beams, curtains are included in the analysis model. In the fully rigid diaphragm solution, the slabs are solved separately and the loads are given to the beams.For more information, click the link below:"unalmh":1somsk18" said:3) I would appreciate if friends who know the differences between fully rigid and semi-rigid solving the system can explain.
file extension. but even if the wrong extensions are the same, if you save it with 8.62, you cannot open it with 8.5, in fact, it would be more correct if the project file saved with 8.62 had the extension 862.1) I downloaded the 8.62 version, but when saving the project, it saves it in 8.5 format. I think this is from the
I think the feature should not be reduced, the file version can be independent of the extension, as a result, will there be a license fee when switching from v8 to v9?"Ismail Hakkı Feeds":1zc54p8a" said:It is planned to save only as project name.ide in version 9.xx. it will probably be removed.
