ideCAD 8.62 registry error
Hello, This warning is caused by the Turkish character problem. You should edit the language and region settings of your computer in Turkish. If this warning appears when your settings are in Turkish, you must first select a different language and country and restart your computer. Then, if you select Turkish and Turkey again and restart, the problem will be fixed.
