Idecad 6.54 Formwork Reinforcement Plan Beam Reinforcement Table Not Formed
MustafaUcoz
Dear Idecad users, Although there are no geometric or other errors in the project I have made, when I create the Floor formwork and reinforcement drawings after analyzing, the beam reinforcement table (flat with beam names, in the form of assembly pile) is not created even though it is marked in the drawing properties. But when I click on the reinforced concrete beam, I can see the number of reinforcements. Such a problem did not exist in the demo versions I have used before. I will be grateful if you could help me. You can check the screenshot of the drawings and features I want to express below in order to understand it more easily. Thanks in advance for your help.
Re: Idecad 6.54 Formwork Reinforcement Plan Beam Reinforcement Table Formation
"MustafaUcoz":3i59bzk0" said:
Dear Idecad users, Although there is no geometric or other error in the project I have made, after analyzing the Floor formwork and when I create the reinforcement drawings, the beam reinforcement table (flat with beam names, in the form of mounting pile) is not created even though it is marked in the drawing properties. But when I click on the reinforced concrete beam, I can see the number of reinforcements. Such a problem was not present in the demo versions I have used before. I would appreciate if you could help. You can check the screenshot of the drawings and features I want to express in order to understand it more easily.Thanks in advance for your help.
Beam Reinforcement table is created on the Beam expansions sheet.
