- AFTER LOADING IDE 8 STEEL-REINFORCED CONCRETE, CLICK ON THE STAIRS TOOL BAR AT IDE 7, THE PROGRAM CLOSES. there is usually a problem with the video card, if you learn the model of your video card and install the latest version driver, the problem will be fixed. ideCAD 8 Installation does not affect previous versions.
"ishak":15uod2mf" said:
- OPEN THE PROJECT DONE IN 7 AT 8 AND ANALYZE IN 7 KUTARAN GIVES AN Error at 8,
When you open your 7th version project at 8, check it especially in terms of wall loads. You may be solving the structure under different loads as the wall load definitions have been changed in 8 versions. In the dynamic analysis report, the total weight of the structure can be checked in 7 and 8 versions ( W ).
EVERYTHING IS MIXED WHEN SAVING IT TO IDE7 AS OLD VERSION, ESPECIALLY FLOOR AND BEAMS ARE DAMAGED. It is within our knowledge.
