ide 8,503 flooring definition
Hello, In the project you added, the jeans of the surrounding elements are not compatible in the eyes you showed. Therefore, the floor cannot be placed. In the previous version, you placed the tile, but the geometry control will warn wrong tile . In the compartments you specified, if two different floors, there must be another element at the same level between K75-K81. If there will be a single slab [/u] across , you must define a tile edge where P8 is located. For this, define pitch P8 from the top. Then draw a trim edge from under the P8 curtain. Set the floor level to zero in the floor settings and place the tile.
SO I CAN'T DEFINE A PLATE BETWEEN P8 AND K76 (at +0.00 elevation) and continue processing. LET ME MAKE SURE THAT I ALREADY HAVE THE CHANCE TO HOLD THE BUILDING ENTRANCE BETWEEN K76 AND P8 AND DEFINE A BEAM A METER ABOVE. WE CANNOT DEFINE THE EDGE OF EACH FLOOR AT DIFFERENT LEVELS OR THE EDGE OF THE FLOOR HOW CAN YOU GIVE AN Idea?
"design_building":3dfsrxz3" said:
SO, SO I CAN'T DEFINE A PLATE BETWEEN P8 AND K76 (At the elevation of +0.00) and continue processing. WE CAN'T DEFINE A BEAM OR FLOOR SIDE AT DIFFERENT LEVELS, HOW WE CAN GIVE YOU AN Idea?
If you define it as you wish and you will continue your project. If you contact us on 0 224 220 67 17, we can show you how to make such data entries by connecting to your computer with remote access.
I UPGRADED THE BEAM LEVEL AND LOWER IT LATER IT SAYS THERE IS AN ERRORS IN GEOMETRY CONTROL BUT I THINK IT'S NOT THAT IMPORTANT. IF I HAVE DIFFICULTY, I WILL CONTACT YOU WITH THE NUMBER YOU PROVIDED. GOOD WORK
"design_building":2r7mjvel" said:
I UPGRADED THE BEAM LEVELS AND LATER I LOWER IT IT SAYS FAULT IN GEOMETRY CONTROL BUT I THINK IT'S NOT THAT IMPORTANT. IF I EXPERIENCED DIFFICULTY I EXPERIENCED THE LOAD IF I EXPERIENCED THE LOAD IF YOU EXPERIENCE [CONDITION], I DON'T EXPERIENCE THE LOAD. Because you're attaching it to that floor.
