IDE 6.053 PUSHOVER ANALYSIS
emrebagdu
Hello. I couldn't see the push analysis in the last version 6.053 I used. It was in the enterprise version 5.511 that I last used.
As you know, the infrastructure of the program was completely renewed in version 6. Pushover analysis suitable for the new infrastructure is not available in version 6 for now, as there is not much demand from our users. But it will be added in future updates. For pushover analysis, use version 5 until update.
Pushover analysis was an analysis that we used a lot in 5 versions, we want it again, please. In order to use the 5 versions, we need to re-enter the project in 5 versions. Greetings Suat
I want to see ide 6 as soon as possible, I think it is necessary for the buildings we do nonlinear analysis. I also met with Mr. Yasin, but in the next update, I would appreciate if the hull reinforcement requirement in article tdy 3.4.1.1 C in continuous foundations is fulfilled, because in the last version, this reinforcement is not used in short foundations, good work.
I agree with my friends, this analysis should be put back into the program as soon as possible. We can't open the project we entered in 6 versions already in 5 versions. this is a very big problem, we will enter the big project again in 5th version.
Before entering the project, you already have the retrofit project information. Enter these projects with version 5. The 6 version is reading the 5 version projects. ideYAPI has focused on drawing works these days. I don't think they will integrate Pushover analysis into 6 versions before these drawing works are finished.
"cassabotanic":13o73yq1" said:
ide YAPI has focused on drawing works these days. I don't think they will integrate Pushover analysis into 6 versions before these drawing works are finished.
IdeYAPI is related to the improvement and development of analysis and drawing facilities, (argeyi We made many suggestions and requests (which angered Mr. Faruk from time to time) .. If my guesses are correct, these studies are currently being handled in İdeYAPI R&D. When the works come to an appropriate consistency, with an update in which the programs and possibilities are increased, "Everything is planned, I believe that it will go as we designed and calculated.. By the way, Pushover analysis is also important. Even though it is not very attractive to go back to old versions, we can bear for the work that ide YAPI will do in this process for a while.. I wish IdeYAPI success and convenience in its work..
